[postgis-devel] [PostGIS] #584: Check of Measure Test is failed
trac at osgeo.org
Fri Sep 10 14:52:49 PDT 2010
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
After compile of postgis I' m having a failed check on Measures tests.
measures. failed (diff expected obtained:
/tmp/pgis_reg_31425/test_24_diff)
The contains of test_24_diff is this:
*** measures_expected Fri Sep 10 23:50:16 2010
--- /tmp/pgis_reg_31425/test_24_out Fri Sep 10 23:53:49 2010
*** 40,46 ****
distancepoly6|0|32.5269119345812|LINESTRING(2 2,2 2)|LINESTRING(2 2,2
2)|LINESTRING(2 2,25 25)|LINESTRING(25 25,2 2)
3dDistancetest1|6.40312423743285|6.40312423743285|f|f|LINESTRING(1 1 1,3
2 7)|POINT(1 1 1)|LINESTRING(1 1 1,3 2 7)
3dDistancetest2|0|1.73205080756888|t|t|LINESTRING(1 1 1,1 1 1)|POINT(1 1
1)|LINESTRING(1 1 1,0 0 0)
! 3dDistancetest3|4.09994192757944|6.48074069840786|t|f|LINESTRING(1 1
1,0.619047619047619 -0.190476190476191 4.90476190476191)|POINT(1 1
1)|LINESTRING(1 1 1,5 2 6)
3dDistancetest4|2|10.0498756211209|t|f|LINESTRING(1 1 3,1 1 1)|POINT(1 1
3)|LINESTRING(5 7 8,1 1 1)
ERROR: Linestring to Linestring distance measures is not yet supported
for 3d
emptyPolyArea|0
--- 40,46 ----
1,0.619047619047619 -0.19047619047619 4.90476190476191)|POINT(1 1
for 3d
emptyPolyArea|0
I use
Debian Lenny 32 bit.
Postgres 9.0 rc1
Geos svn r3104
Postgis r5960
Ticket URL: <http://trac.osgeo.org/postgis/ticket/584>
