[postgis-devel] [PostGIS] #589: [raster] Implement ST_SameAlignment
trac at osgeo.org
Wed Sep 15 08:20:12 PDT 2010
Reporter: pracine | Owner: jorgearevalo
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Description changed by pracine:
Old description:
> This function is of general use and is required by the two raster version
> of ST_MapAlgebra. See the code in script/plpgsql/mapalgebra.sql
New description:
It should be implemented in the core receiving two detoasted rasters.
A ST_SameAlignment SQL function should then be added.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/589#comment:2>
