[postgis-devel] The limits of integration
Paul Ramsey
pramsey at cleverelephant.ca
Wed Sep 15 12:43:33 PDT 2010
Agreed with Regina.
P.
On 2010-09-15, at 11:33 AM, "Paragon Corporation" <lr at pcorp.us> wrote:
> Pierre,
> I think having the .so/dd be separate for now is fine and I would keep it
> that way until we confirm the whole project builds together.
> The SQL file should be kept as a separate file as postgis.sql.in.c is
> already too big.
> I kind of like the way we handled geography. The geography.sql.in.c file
> is maintained as a separate but then gets merged in to build the
> postgis.sql.
> At any rate it should stay as a separate rtpostgis.sql.in.c file like the
> geography does to keep things a bit sane and then in the final build gets
> tacked on to postgis.sql, but I don't see the need to do that right away.
> I think we should just bring all the raster stuff in as separate. Do a
> couple of builds with it being part of the make file but built as separate
> dll/so .sqls and then when all looks stable then dissolve the boundaries.
> Just my 2 cents,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Pierre
> Racine
> Sent: Wednesday, September 15, 2010 2:17 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] The limits of integration
> Hi,
> So I guess there are some limits to the integration of the raster part. I
> guess we want to keep a different shared library and a different .sql file?
> The shared lib is now named rtpostgis. Ok with that name? Or should it
> becomes postgisrt-2.0.so? Or something else?
> The official name of the raster extension should now be "The PostGIS RASTER
> type" in place for the "bad" "WKT Raster".
> Thanks,
> Pierre
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
