[postgis-devel] [PostGIS] #522: pgsql2shp ignoring the -f switch
trac at osgeo.org
Sat Sep 18 08:33:32 PDT 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Resolution: | Keywords:
Comment(by robe):
Okay I'll check next I get the chance. I can assure you though the syntax
I posted above used to work. In fact all I have to do to get it to work
is to revert the pgsql2shp (to I think early 1.5 or 1.4).
Though I guess you are right in theory it should never have worked though
it did :).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/522#comment:8>
