[postgis-devel] [PostGIS] #513: Can't upload dbf only with gui (without unchecking index?)
trac at osgeo.org
Sat Sep 18 12:13:56 PDT 2010
Reporter: robe | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
As I recall the commandline doesn't care if a dbf extension, .shp or no
extension is given. It will load the shp unless an explicit dbf-only
command is given or there is no accompanying shp. The gui should behave
the same way to be consistent.
Anyrate I think its fine the way you have it as long as the .shp is the
default filter.
At some point we should add a dbf only option checkbox like the
commandline has but that is a task for another day.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/513#comment:5>
