[postgis-devel] State of shp2pgsql-gui in trunk
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Sun Sep 19 05:55:22 PDT 2010
Hi folks,
Having just been applying fixes to shp2pgsql-gui in both trunk and 1.5,
I am getting quite concerned about the state of shp2pgsql-gui in trunk.
Here are a few of the issues I have noticed with current trunk:
- Multiple warnings at build-time
gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
-I/home/pg83/rel-8.3.7/include -D_REENTRANT -I/usr/include/gtk-2.0
-I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo
-I/usr/include/pango-1.0 -I/usr/include/glib-2.0
-I/usr/lib/glib-2.0/include -I/usr/include/pixman-1
-I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12
-o shp2pgsql-gui.o -c shp2pgsql-gui.c
shp2pgsql-gui.c:155: warning: no previous prototype for ‘pgui_log_va’
shp2pgsql-gui.c: In function ‘compare_columns’:
shp2pgsql-gui.c:1000: warning: enumeration value ‘FTInvalid’ not handled
in switch
shp2pgsql-gui.c: In function ‘pgui_create_file_table’:
shp2pgsql-gui.c:2369: warning: unused variable ‘bin_window’
shp2pgsql-gui.c: At top level:
shp2pgsql-gui.c:1675: warning: ‘pgui_action_null’ defined but not used
shp2pgsql-gui.c: In function ‘pgui_action_shape_file_set’:
shp2pgsql-gui.c:1713: warning: ‘status’ may be used uninitialized in
this function
shp2pgsql-gui.c: In function ‘pgui_action_handle_tree_edit’:
shp2pgsql-gui.c:666: warning: ‘status’ may be used uninitialized in this
function
- Multiple GTK assertions triggered at run time
e.g.
(shp2pgsql-gui:29945): GLib-GObject-WARNING **:
/build/buildd-glib2.0_2.22.4-1~bpo50+1-amd64-SJ3EDw/glib2.0-2.22.4/gobject/gsignal.c:2270:
signal `changed' is invalid for instance `0x6becc0'
(shp2pgsql-gui:29945): GLib-GObject-WARNING **: IA__g_object_set_valist:
object class `GtkCellRendererToggle' has no property named `editable'
(shp2pgsql-gui:29945): Gtk-CRITICAL **: gtk_list_store_get_value:
assertion `column < list_store->n_columns' failed
(shp2pgsql-gui:29945): GLib-GObject-CRITICAL **: g_object_set_property:
assertion `G_IS_VALUE (value)' failed
(shp2pgsql-gui:29945): GLib-GObject-CRITICAL **: g_value_unset:
- Bitrot/regressions compared to 1.5 branch
It looks as if the merge into trunk has removed some of the later
changes from the 1.5 branch, e.g. take a look at pgui_read_connection().
The version in trunk has now regressed to a much older version, and is
totally different from the logic in the 1.5 branch. Does that mean that
there are other instances of this from the merge?
- Test connection always displays "Connection Succeeded" even when it
doesn't?!
- General code quality issues:
Random bits of code are commented out with no explanation, e.g
shp2pgsql-gui lines 43-46, and lines 1176-1179. These sections need to
either be fixed up or removed. Also what does the sqlform query do? It's
not obvious and needs a comment. Some sections of code are still marked TBD.
To summarise, my feeling is that in its current state this code is not
ready for the prime time, and the maintenance is going upwards due to
trunk not being based on a recent version of 1.5 branch. I think someone
needs to step up to fix/maintain this code ASAP or we should simply
revert the changes and re-synchronise with the 1.5 branch :(
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
