[postgis-devel] PostGIS 1.5.2 are we ready for release?
Paragon Corporation lr at pcorp.us
Fri Sep 24 11:08:39 PDT 2010
Paul, Kevin and Mark,
You think we are ready for release yet?  Seems fine to me.
As far as the 2 errors I got in 9.0.  I confirmed it's a new feature that
when you do a SELECT INTO or CREATE TABLE AS
The output also gives count of records.  Snippet from release notes:
"Make SELECT INTO and CREATE TABLE AS return row counts to the client in
their command tags (Boszormenyi Zoltan)
This can save an entire round-trip to the client, allowing result counts and
pagination to be calculated without an additional COUNT query. "
 I suppose we can change our regress to do a CREATE and then insert or
something, but certainly no reason to hold up the release.
Thanks,
Regina
