[postgis-devel] PostGIS 1.5.2 are we ready for release?
Paragon Corporation
lr at pcorp.us
Fri Sep 24 11:26:09 PDT 2010
+1 Yes lets comment them out.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Friday, September 24, 2010 2:18 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] PostGIS 1.5.2 are we ready for release?
Well, it's a shame to have regression noise in a final release... and it's a
shame every new pgsql release gives us new regression issues to work around
Let me quickly look at those cases, I would vote for commenting them out of
this release so we don't release aomething with failing 'make check'
results.
P.
On Fri, Sep 24, 2010 at 11:08 AM, Paragon Corporation <lr at pcorp.us> wrote:
> Paul, Kevin and Mark,
> You think we are ready for release yet? Seems fine to me.
> As far as the 2 errors I got in 9.0. I confirmed it's a new feature
> that when you do a SELECT INTO or CREATE TABLE AS
> The output also gives count of records. Snippet from release notes:
> "Make SELECT INTO and CREATE TABLE AS return row counts to the client
> in their command tags (Boszormenyi Zoltan)
> This can save an entire round-trip to the client, allowing result
> counts and pagination to be calculated without an additional COUNT query.
> I suppose we can change our regress to do a CREATE and then insert or
> something, but certainly no reason to hold up the release.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
