[postgis-devel] PostGIS 1.5.2 is finally out
Paragon Corporation
lr at pcorp.us
Mon Sep 27 09:40:12 PDT 2010
The PostGIS Project Steering Committee is proud to announce the official
release of PostGIS 1.5.2
after extensive prodding from the PostGIS community of packagers and users
(Thanks Devrim : ) )
The source tar ball can be downloaded from:
http://www.postgis.org/download/
This is a minor release addressing a few issues that have been filed since
the 1.5.1 release in addition to fixes that allow it to compile seamlessly
against
PostgreSQL 9.0.
Bug Fixes
* Loader: fix handling of empty (0-verticed) geometries in shapefiles.
(Sandro Santilli)
* #536, Geography ST_Intersects, ST_Covers, ST_CoveredBy and Geometry
ST_Equals not using spatial index (Regina Obe, Nicklas Avén)
* #573, Improvement to ST_Contains geography
* Loader: Add support for command-q shutdown in Mac GTK build (Paul
Ramsey)
* #393, Loader: Add temporary patch for large DBF files (Maxime
Guillaud, Paul Ramsey)
* #507, Fix wrong OGC URN in GeoJSON and GML output (Olivier Courtin)
* spatial_ref_sys.sql: Add datum conversion for projection SRID 3021
(Paul Ramsey)
* Geography: remove crash for case when all geographies are out of the
estimate (Paul Ramsey)
* #469, Fix for array_aggregation error (Greg Stark, Paul Ramsey)
* #532, Temporary geography tables showing up in other user sessions
(Paul Ramsey)
* #562, ST_Dwithin errors for large geographies (Paul Ramsey)
* #513, shape loading GUI tries to make spatial index when loading DBF
only mode (Paul Ramsey)
* #527, shape loading GUI should always append log messages (Mark
Cave-Ayland)
* #504, shp2pgsql should rename xmin/xmax fields (Sandro Santilli)
* #458, postgis_comments being installed in contrib instead of version
folder (Mark Cave-Ayland)
* #474, Analyzing a table with geography column crashes server (Paul
Ramsey)
* #581, LWGEOM-expand produces inconsistent results (Mark Cave-Ayland)
* #471, DocBook dtd errors (Olivier Courtin)
* Fix further build issues against PostgreSQL 9.0 (Mark Cave-Ayland)
* #572, Password whitespace for Shape File to PostGIS Import not
supported (Mark Cave-Ayland)
* shp2pgsql: "-w" produces invalid WKT for MULTI* objects. (Mark
Cave-Ayland)
Enhancement
* #513, Add dbf filter to shp2pgsql-gui and allow uploading dbf only
(Paul Ramsey)
Windows builds will be out later this week or early next and also available
on Stackbuilder. We are also working on 64-bit windows build for PostgreSQL
9.0 which we hope to have soon.
Thanks from the loving PostGIS PSC,
Kevin, Mark, Paul and Regina
