[postgis-devel] array construct in measures.c
Mateusz Loskot
mateusz at loskot.net
Wed Sep 29 13:19:45 PDT 2010
On 29/09/10 21:08, Nicklas Avén wrote:
> Hallo
> I saw that Paul has put a comment in measures.c that C90 doesn't support
> var-size array. I suspect that is what gave Sami problems when compiling
> PostGIS with Visual Studio as mentioned here:
> http://symbiatch.jutut.fi/article/2955
> So, in attached patch, am I doing it the right way?
You may check patches Mark committed some time ago
when I was attempting to build PostGIS using Visual C++
http://trac.osgeo.org/postgis/changeset/3828
http://trac.osgeo.org/postgis/changeset/3848
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
