[postgis-devel] [PostGIS] #103: Box3D always gets cast to 2D geometry
trac at osgeo.org
Sat Apr 2 00:36:28 PDT 2011
Reporter: robe | Owner: strk
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by strk):
* owner: robe => strk
* status: reopened => new
Old description:
> Actually not sure if this is solvable. But ST_SetSRID, ST_Force_3DZ all
> lose the Z coordinate value of a BOX3D.
> Example:
> SELECT ST_AsEWKT(ST_Force_3DZ(ST_Extent3D(foo.the_geom))) As
> b3extentpoly,
> ST_Extent3D(foo.the_geom) As b3extent
> FROM (SELECT ST_MakePoint(x,y,z) As the_geom
> FROM generate_series(1,3) As x
> CROSS JOIN generate_series(1,2) As y
> CROSS JOIN generate_series(0,2) As Z) As foo;
> Yields:
> b3extentpoly b3extent
> POLYGON((1 1 0,1 2 0,3 2 0,3 1 0,1 1 0)) ;BOX3D(1 1 0,3 2 2)
> I would expect the POLYGON value to have some 2 z coords in there.
New description:
Example:
SELECT ST_AsEWKT(ST_Force_3DZ(ST_Extent3D(foo.the_geom))) As b3extentpoly,
Yields:
Ticket URL: <http://trac.osgeo.org/postgis/ticket/103#comment:3>
