[postgis-devel] [PostGIS] #887: Tiger geocoder fails when address contains name of state sometimes
trac at osgeo.org
Mon Apr 4 16:26:00 PDT 2011
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Fixed at r7005. The problem was that the normalize wouldn't work if
state abbrev, zip was separated with a , instead of a space. So:
GEOCODE('2450 N COLORADO ST, PHILADELPHIA, PA 19132')
probably worked fine though probably thru an error:
GEOCODE('2450 N COLORADO ST, PHILADELPHIA, PA, 19132')
Ticket URL: <http://trac.osgeo.org/postgis/ticket/887#comment:3>
