[postgis-devel] [PostGIS] #869: ticket #304 regress is failing
PostGIS trac at osgeo.org
Wed Apr 6 07:21:18 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Looking at the culprit changeset (r6924) this was suspicious:
 - if ( gserialized_datum_overlaps(PG_GETARG_DATUM(0),PG_GETARG_DATUM(1))
 == LW_TRUE )
 + if ( gserialized_datum_predicate(PG_GETARG_DATUM(0),PG_GETARG_DATUM(1),
 gidx_contains) == LW_TRUE )
 The attached patch uses 'gidx_overlaps' instead of 'gidx_contains'.
 Fixes regress/ make check for me.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/869#comment:5>
