[postgis-devel] [PostGIS] #901: [raster] ST_AsGDALRaster and the helper functions ST_getGDALDrivers and ST_srtext
trac at osgeo.org
Wed Apr 6 11:08:44 PDT 2011
ST_srtext
Reporter: dustymugs | Owner: pracine
Type: task | Status: new
Priority: medium | Milestone: PostGIS Raster Future
Component: postgis | Version: trunk
Keywords: |
What follows is a proposal on the specifics of ST_AsGDALRaster and two
supporting functions.
This is a generic interface to outputting a supported and installed GDAL
raster:
ST_AsGDALRaster(rast raster, format text, options text[], srs text) ->
bytea
This is the most generic and GDAL-specific method to convert a raster
to a GDAL raster. All other version of ST_AsGDALRaster and other format
specific functions (ST_AsJPEG, ST_AsTIFF and ST_AsPNG) are all wrappers
around this function. Reference information for the format and options
arguments of a particular format are specified at:
http://gdal.org/formats_list.html. The arguments specified are:
format: the GDAL format code. e.g. GTiff, JPEG, PNG
options: the GDAL creation options found in the Creation Options
section of a specified format. e.g. COMPRESS=JPEG, JPEG_QUALITY=90
srs: the user-specified OGC WKT or the proj4 text for a spatial
reference to embed in the GDAL raster. Not all formats support embedding
this information. e.g. the non-empty value for the srtext or proj4text
column from the spatial_ref_sys table.
ST_AsGDALRaster(rast, 'GTiff', ARRAY['COMPRESS=JPEG', 'JPEG_QUALITY=90'],
'+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000
+ellps=GRS80 +datum=NAD83 +units=m +no_defs')
'PROJCS["NAD83 / California
Albers",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS
1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["standard_parallel_1",34],PARAMETER["standard_parallel_2",40.5],PARAMETER["latitude_of_center",0],PARAMETER["longitude_of_center",-120],PARAMETER["false_easting",0],PARAMETER["false_northing",-4000000],AUTHORITY["EPSG","3310"],AXIS["X",EAST],AXIS["Y",NORTH]]')
ST_AsGDALRaster(rast raster, format text, options text[]) -> bytea
This one removes the user-specified srs argument. The output GDAL
raster's spatial reference will be set to the same as the input raster, if
possible.
ST_AsGDALRaster(rast, 'JPEG', ARRAY!['QUALITY=50'])
ST_AsGDALRaster(rast, 'PNG', ARRAY!['ZLEVEL=7'])
ST_AsGDALRaster(rast raster, format text) -> bytea
The simplest implementation of this function. Since the options
argument has been removed, the output GDAL raster will be created with
default options. Like the prior function, the spatial reference of the
GDAL raster will be set to the same as the input raster.
ST_AsGDALRaster(rast, 'JPEG')
The two helper functions are:
ST_getGDALDrivers() -> set of record
As each GDAL installation may be different and ST_AsGDALRaster can be used
to support formats other than GTiff, JPEG and PNG, a method is needed to
expose to the end user the possible GDAL formats capable of being
exported. This function will output the following columns.
idx: the internal GDAL index number
short_name: the GDAL format code. This is the value to pass to the
format paramenter of ST_AsGDALRaster
long_name: the full name of the GDAL format
create_options: the creation options available for the format as an
XML string.
SELECT * FROM ST_getGDALDrivers()
The formats outputted from ST_getGDALDrivers have been filtered to only
those that the GDAL capabilities !CreateCopy and Virtual IO support.
Should the GDAL raster process be capable of supporting the GDAL
capability Create? As the GDAL raster process writes nothing to a file in
the filesystem (via Virtual IO), should there be support for writing the
output GDAL raster temporarily to the filesystem? If so, how is it done in
other PostgreSQL extensions in a secure manner?
ST_srtext(rast raster) -> text
A helper function to get the value of column srtext or proj4text for a
raster with an SRID. By default, the srtext is returned. If srtext is not
available but proj4text is, the proj4text is returned.
SELECT ST_srtext(rast);
This function may be removed based upon the capabilities of SPI. It may
not be possible to remove this function as the srs function argument of
ST_AsGDALRaster can be NULL, thereby instructing the function to not embed
any spatial reference information into the output GDAL raster.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/901>
