[postgis-devel] [PostGIS] #851: [raster] Numerous ST_Value query cause the memory to grow indefinitely
PostGIS trac at osgeo.org
Wed Apr 6 23:47:46 PDT 2011
 Reporter:  pracine         |       Owner:  jorgearevalo
     Type:  defect          |      Status:  assigned
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Changes (by jorgearevalo):
  * status:  new => assigned
Comment:
 For the record: After 8h executing the query in a 64bits machine, with a
 10x10px tiled raster, it took 240MB. 180MB from heap. And growing. As
 Pierre said, typical memory leak.
 Same symptom in MapAlgebra, like Pierre said too. And there're 2 common
 potential memory-leak points:[[BR]]
 - rt_context_new: context allocated is not freed. It should be always
 freed.[[BR]]
 - rt_raster_deserialize: allocated memory for raster object. It should be
 always freed. Even when the function returns that raster, because the
 raster is serialized again before returning it.[[BR]]
 Freeing that memory should solve the memory leak. Testing it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/851#comment:16>
