[postgis-devel] [PostGIS] #341: [raster] Implement ST_AsTIFF function for raster
trac at osgeo.org
Thu Apr 7 07:46:04 PDT 2011
Reporter: mloskot | Owner: dustymugs
Type: task | Status: new
Priority: medium | Milestone: PostGIS Raster Future
Component: postgis raster | Version: trunk
Keywords: |
Changes (by dustymugs):
* owner: mloskot => dustymugs
Comment:
A proposed implementation of the ST_AsTIFF functions.
The TIFF format is probably the most robust available for converting
rasters to GDAL rasters. Not only does it support all PostGIS Raster
pixel types, it also provides plenty of creation options and possibly no
issues with the number of bands. The only limitation found is that there
can only be one NODATA value for all bands.
The next three functions are the most basic of the ST_AsTIFF functions.
ST_AsTIFF(rast raster, options text[], srs text) -> bytea
The most generic version of this function. All other ST_AsTIFF
functions call this function.
This function will check that all bands of the raster to be converted
has the same NODATA value. If there are more than one possible NODATA
values, a WARNING will be raised and the output TIFF will use the NODATA
value of the last band with a NODATA value.
options: the GDAL creation options found in the Creation Options
section of the GDAL TIFF driver
srs: the user-specified OGC WKT or the proj4 text for a spatial
reference to embed in the GDAL raster. TIFF is one of the formats that
supports embedding the spatial reference within the image file.
ST_AsTIFF(rast, ARRAY['COMPRESS=DEFLATE', 'ZLEVEL=9'], '+proj=aea
+lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000
+ellps=GRS80 +datum=NAD83 +units=m +no_defs')
ST_AsTIFF(rast, ARRAY['COMPRESS=DEFLATE', 'ZLEVEL=9'], 'PROJCS["NAD83 /
California
Albers",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS
1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["standard_parallel_1",34],PARAMETER["standard_parallel_2",40.5],PARAMETER["latitude_of_center",0],PARAMETER["longitude_of_center",-120],PARAMETER["false_easting",0],PARAMETER["false_northing",-4000000],AUTHORITY["EPSG","3310"],AXIS["X",EAST],AXIS["Y",NORTH]]')
ST_AsTIFF(rast raster, options text[]) -> bytea
This one removes the user-specified srs argument. The output TIFF's
spatial reference will be set to the same as the input raster, if
possible.
ST_AsTIFF(rast, ARRAY['COMPRESS=DEFLATE', 'ZLEVEL=9'])
ST_AsTIFF(rast raster) -> bytea
The simplest implementation of this function. Since the options argument
has been removed, the output TIFF will be created with default options.
Like the prior function, the spatial reference of the TIFF will be set to
the same as the input raster.
ST_AsTIFF(rast)
The next three functions add a band index argument to filter the raster's
bands before generating the output TIFF.
ST_AsTIFF(rast raster, nbands int[], options text[], srs text) -> bytea
ST_AsTIFF(rast, ARRAY[3,1,2], ARRAY['COMPRESS=DEFLATE', 'ZLEVEL=9'],
'+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000
ST_AsTIFF(rast raster, nbands int[], options text[]) -> bytea
possible.
ST_AsTIFF(rast, ARRAY[3,1,2], ARRAY['COMPRESS=DEFLATE', 'ZLEVEL=9'])
ST_AsTIFF(rast raster, nbands int[]) -> bytea
Since the options argument has been removed, the output TIFF will be
created with default options. Like the prior function, the spatial
reference of the TIFF will be set to the same as the input raster.
ST_AsTIFF(rast, ARRAY[3,1,2])
The next three functions add a compression argument. If the compression
desired is JPEG or DEFLATE, the user can specify a quality as part of the
compression string.
Examples are:
JPEG90
DEFLATE8
ST_AsTIFF(rast raster, compression text, options text[], srs text) ->
bytea
This function will parse the compression string for the compression type
and the compression quality. It will also inspect to make sure that the
pixel types of the raster's bands are appropriate for the compression
type. This is primarily for JPEG and CCITT compression types, which only
support 8BUI and 1BB respectively.
ST_AsTIFF(rast, 'JPEG90', ARRAY['BIGTIFF=IF_NEEDED'], '+proj=aea +lat_1=34
+lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80
ST_AsTIFF(rast, 'JPEG', ARRAY['BIGTIFF=IF_NEEDED'], '+proj=aea +lat_1=34
ST_AsTIFF(rast, 'LZMA', ARRAY['BIGTIFF=IF_NEEDED'], '+proj=aea +lat_1=34
ST_AsTIFF(rast raster, compression text, options text[]) -> bytea
possible.
ST_AsTIFF(rast, 'DEFLATE9', ARRAY['PROFILE=GeoTIFF'])
ST_AsTIFF(rast raster, compression text) -> bytea
The output TIFF will be created with default options. Like the prior
function, the spatial reference of the TIFF will be set to the same as the
input raster.
ST_AsTIFF(rast, 'LZMA')
The next three functions include band index and compression arguments
ST_AsTIFF(rast raster, nbands int[], compression text, options text[], srs
text) -> bytea
ST_AsTIFF(rast, ARRAY[2], 'JPEG90', ARRAY['BIGTIFF=IF_NEEDED'], '+proj=aea
ST_AsTIFF(rast, ARRAY[1,3], 'JPEG', ARRAY['BIGTIFF=IF_NEEDED'], '+proj=aea
ST_AsTIFF(rast, ARRAY[3,1,2], 'LZMA', ARRAY['BIGTIFF=IF_NEEDED'],
ST_AsTIFF(rast raster, nbands int[], compression text, options text[]) ->
bytea
possible.
ST_AsTIFF(rast, ARRAY[2], 'DEFLATE9', ARRAY['PROFILE=GeoTIFF'])
ST_AsTIFF(rast raster, nbands int[], compression text) -> bytea
ST_AsTIFF(rast, ARRAY[3,2], 'DEFLATE9')
input raster.
Any thoughts before I add this to the wiki?
Also, I wonder if this is an excessive number of possible functions. I
ask because I'm wondering if I should add additional possible ways to
specify the nbands argument (a single integer or a text string).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/341#comment:7>
