[postgis-devel] [PostGIS] #851: [raster] Numerous ST_Value query cause the memory to grow indefinitely
trac at osgeo.org
Thu Apr 7 11:21:49 PDT 2011
Reporter: pracine | Owner: jorgearevalo
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by strk):
The core deserializer uses allocators set in the rt_context.
In the rt_pg case, this is palloc, which is supposed to release the memory
when the associated pool goes out of scope.
Now, the scope might be wider than you'd like, in which case it's fine to
release manually, but it shouldn't live cross a single query.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/851#comment:19>
