[postgis-devel] [PostGIS] #908: linux version of tiger2010 geocoder does not work
PostGIS trac at osgeo.org
Thu Apr 14 02:33:11 PDT 2011
 Reporter:  donh            |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  1.5.X
 Keywords:                  |
Comment(by mcayland):
 > shp2pgsql does not really convert latin1 to utf-8 all the time so I
 added a "| iconv -f latin1
 > -t UTF8 | $PGBIN/psql" after the shp2pgsql command. That did away with
 the aborted transactions
 > from postgresql.
 If this is true, then you've found a bug. Can it be reproduced using the
 files attached to this ticket?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/908#comment:1>
