[postgis-devel] [PostGIS] #909: cu_tester segfaults on 64bit system
trac at osgeo.org
Thu Apr 14 03:43:33 PDT 2011
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
(gdb) run
Starting program: /home/src/postgis/postgis/liblwgeom/cunit/cu_tester
CUnit - A Unit testing framework for C - Version 2.1-0
http://cunit.sourceforge.net/
Suite: print_suite
Test: test_lwprint_default_format ...
Program received signal SIGSEGV, Segmentation fault.
0x000000000048d660 in strcmp ()
(gdb) bt
#0 0x000000000048d660 in strcmp ()
#1 0x0000000000404417 in test_lwprint_assert_format (
point_wkt=<value optimized out>, format=<value optimized out>,
expected=0x44df05 "0°0'0.000\"N 0°0'0.000\"E") at cu_print.c:35
#2 0x0000000000404795 in test_lwprint_default_format () at cu_print.c:65
#3 0x00007ffff79512aa in ?? () from /usr/lib/libcunit.so.1
#4 0x00007ffff79516ee in ?? () from /usr/lib/libcunit.so.1
#5 0x00007ffff7951828 in CU_run_all_tests () from /usr/lib/libcunit.so.1
#6 0x0000000000411675 in main (argc=1, argv=0x7fffffffe0e8) at
cu_tester.c:100
Ticket URL: <http://trac.osgeo.org/postgis/ticket/909>
