[postgis-devel] [PostGIS] #918: two bugs in Populate_Geometry_Columns(oid)
trac at osgeo.org
Wed Apr 20 02:21:50 PDT 2011
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
From report by Anders Söderman that Populate_Geomtry_columns gives primary
key violation in geometry_columns table
Populate_geoemtry_columns(oid) does not delete old entries in
geometry_columns if the tabel or schema name includes characters that
makes need of double quoting.
It is working when there is no need for double quoting because quote_ident
don't quote when not needed.
Second bug is that that entries for views is not deleted at all before the
function tries to add a new one which also causes a primary key violation
error.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/918>
