[postgis-devel] [PostGIS] #851: [raster] Numerous ST_Value query cause the memory to grow indefinitely
trac at osgeo.org
Thu Apr 21 12:49:57 PDT 2011
Reporter: pracine | Owner: jorgearevalo
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by pracine):
Here are my results:
CREATE OR REPLACE FUNCTION ST_Values(rast raster, band int, OUT val double
precision)
RETURNS SETOF double precision
AS $$
SELECT ST_Value($1, $2, x, y) val FROM generate_series(1,
ST_Width($1)) x , generate_series(1, ST_Height($1)) y;
LANGUAGE SQL IMMUTABLE;
--Test 1
--With rt_context_destroy(): no memory growth
--Without rt_context_destroy(): very small memory growth
--2600 milliseconds for 10000
SELECT ST_Values(rast, 1) val, count(*) count
FROM srtm_22_03_tiled_10x10
--WHERE rid <= 10000
GROUP BY val
ORDER BY count DESC
--Test 2
--With rt_context_destroy(): very small memory growth
--Without rt_context_destroy(): good memory growth. Crashes eventually.
--90000 milliseconds for 10000
SELECT val, count(*) count
FROM (SELECT ST_Value(rast, 1, x, y) val
FROM generate_series(1, 10) x, generate_series(1, 10) y,
) foo
GROUP BY val
ORDER BY count DESC;
--Test 3
--8500 milliseconds for 10000
--Test 4
--Without rt_context_destroy(): no memory growth
--10000 milliseconds for 10000
SELECT x, y
Conclusion: rt_context_destroy() is still very useful...
Remark: test 2 used to be twice faster than test 1. I will eventually
search further in the code history when it became slower. I suspect a
change in serialization.
The goal of all that is to make sure PL/pgSQL functions can iterate on
every pixels of a coverage fast enough and without crashing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/851#comment:28>
