[postgis-devel] [PostGIS] #851: [raster] Numerous ST_Value query cause the memory to grow indefinitely
PostGIS trac at osgeo.org
Tue Apr 26 04:56:44 PDT 2011
 Reporter:  pracine         |       Owner:  jorgearevalo
     Type:  defect          |      Status:  assigned
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by jorgearevalo):
 Of course. I'm copying the things that work on PostGIS. But the changes
 can be summarized in:
   - using global vars to store memory allocators, instead of a struct
 (rt_context), that must be allocated in every function call.[[BR]]
   - working on the SQL calling function memory context.
 "MemoryContextSwitchTo" is used only when you need a persistent memory
 context to store info (SRF).[[BR]]
 So, it's not so huge change, really.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/851#comment:31>
