[postgis-devel] [PostGIS] #851: [raster] Numerous ST_Value query cause the memory to grow indefinitely
trac at osgeo.org
Tue Apr 26 09:18:19 PDT 2011
Reporter: pracine | Owner: jorgearevalo
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by jorgearevalo):
Understood. The main problem I saw is that every time a raster core
function is called (for example, rt_band_get_pixel) a new chunk of memory
for rt_context is allocated.
This memory is allocated in fcinfo->flinfo->fn_mcxt memory context, a
postgres memory context that has query lifespan, and could be even longer
lived than that. So, this memory allocated for rt_context must be always
released, to avoid memory leaks in cases of losing control because any
postgres function throws a elog(ERROR).
So, following Tom Lane's advices, I think most of the raster core
functions should work in function calling memory context, not in
fcinfo->flinfo->fn_mcxt. The only exception so far is
rt_dump_as_wktpolygons function, that needs to store some data to live
between function calls. For that reason, it uses multi_call_memory_ctx,
the recommended context for this kind of functions (SRF).
Apart from this problem, using a struct to keep pointers to all memory
functions together (like rt_context) instead of using single vars (like
PostGIS does) is not a big deal. But I think a static rt_context var would
be less harmful, in terms of memory consumption.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/851#comment:35>
