[postgis-devel] [PostGIS] #413: ST_OffsetCurve
trac at osgeo.org
Wed Apr 27 06:13:27 PDT 2011
Reporter: rafalmag | Owner: strk
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
FYI: upcoming GEOS-3.3.0 will have offset curve generation refactored.
Part of this is due to JTS introducing proper single sided buffers
(areal).
The C-API function for offset curves will be named GEOSOffsetCurve
deprecating GEOSBufferSingleSided (to avoid confusion with areal single
sided buffers).
An interesting interface found in JTS (for the right/left discourse) was
to use the sign of buffer distance (negative distance == right side). Such
interface might be found in the new GEOSOffsetCurve too.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/413#comment:26>
