[postgis-devel] [PostGIS] #930: [raster] ST_SummaryStats
trac at osgeo.org
Fri Apr 29 10:53:57 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: new
Priority: medium | Milestone: PostGIS Raster Future
Component: postgis raster | Version: trunk
Keywords: |
Like how ST_AsGDALRaster is the backend to ST_AsTIFF, ST_AsJPEG and
ST_AsPNG, ST_SummaryStats is the backend for several summary stats:
1. Count of the population/sample included in the stats
2. Mean (ST_Mean or is ST_Average better?)
3. Standard Deviation (ST_StdDev)
4. !Min/Max (ST_MinMax)
The proposed variations are:
1. ST_SummaryStats(rast raster, nband int, ignore_nodata boolean) ->
record
returns one record of five columns (count, mean, stddev, min, max)
nband: index of band to process on
ignore_nodata: if TRUE, any pixel who's value is nodata is ignored.
ST_SummaryStats(rast, 2, TRUE)
2. ST_SummaryStats(rast raster, nband int) -> record
assumes ignore_nodata = TRUE
ST_SummaryStats(rast, 2)
3. ST_SummaryStats(rast raster, ignore_nodata boolean) -> record
assumes band index = 1
ST_SummaryStats(rast, FALSE)
4. ST_SummaryStats(rast raster) -> record
assumes band index = 1 and ignore_nodata = TRUE
ST_SummaryStats(rast)
Four approximation functions are also proposed sacrificing some accuracy
for speed, especially on large rasters (10000 x 10000).
1. ST_SummaryStats(rast raster, nband int, ignore_nodata boolean,
sample_percent double precision) -> record
sample_percent: a value between 0 and 1 indicating the percentage of
the raster band's pixels to consider when determining the min/max pair.
ST_SummaryStats(rast, 3, FALSE, 0.1)
ST_SummaryStats(rast, 1, TRUE, 0.5)
2. ST_SummaryStats(rast raster, ignore_nodata boolean, sample_percent
assumes that nband = 1
ST_SummaryStats(rast, FALSE, 0.01)
ST_SummaryStats(rast, TRUE, 0.025)
3. ST_SummaryStats(rast raster, sample_percent double precision) -> record
assumes that nband = 1 and ignore_nodata = TRUE
ST_SummaryStats(rast, 0.25)
assumes that nband = 1, ignore_nodata = TRUE and sample_percent = 0.1
New tickets for ST_Mean and ST_StdDev will be posted next.
Functions that can depend upon the basic stats (ST_Histogram and
ST_Quantile) will be proposed later.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/930>
