[postgis-devel] [PostGIS] #932: [raster] ST_StdDev
trac at osgeo.org
Fri Apr 29 11:01:55 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: new
Priority: medium | Milestone: PostGIS Raster Future
Component: postgis raster | Version: trunk
Keywords: |
A function to get the standard deviation (or sample deviation if
approximating) of a raster's band.
1. ST_StdDev(rast raster, nband int, ignore_nodata boolean) -> double
returns the standard deviation
nband: index of band to process on
ignore_nodata: if TRUE, any pixel who's value is nodata is ignored.
ST_StdDev(rast, 2, TRUE)
2. ST_StdDev(rast raster, nband int) -> double
assumes ignore_nodata = TRUE
ST_StdDev(rast, 2)
3. ST_StdDev(rast raster, ignore_nodata boolean) -> double
assumes band index = 1
ST_StdDev(rast, FALSE)
4. ST_StdDev(rast raster) -> double
assumes band index = 1 and ignore_nodata = TRUE
ST_StdDev(rast)
Four approximation functions are also proposed sacrificing some accuracy
for speed, especially on large rasters (10000 x 10000).
1. ST_ApproxStdDev(rast raster, nband int, ignore_nodata boolean,
sample_percent double precision) -> double
sample_percent: a value between 0 and 1 indicating the percentage of
the raster band's pixels to consider in computing the summary stats.
ST_ApproxStdDev(rast, 3, FALSE, 0.1)
ST_ApproxStdDev(rast, 1, TRUE, 0.5)
2. ST_ApproxStdDev(rast raster, ignore_nodata boolean, sample_percent
assumes that nband = 1
ST_ApproxStdDev(rast, FALSE, 0.01)
ST_ApproxStdDev(rast, TRUE, 0.025)
3. ST_ApproxStdDev(rast raster, sample_percent double precision) -> double
assumes that nband = 1 and ignore_nodata = TRUE
ST_ApproxStdDev(rast, 0.25)
4. ST_ApproxStdDev(rast raster) -> double
assumes that nband = 1, ignore_nodata = TRUE and sample_percent = 0.1
ST_ApproxStdDev(rast)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/932>
