[postgis-devel] Planning of raster work to be integrated in PostGIS 2.0
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Fri Apr 29 14:05:10 PDT 2011
Hi all,
As you probably noticed, Bborie Park from the Center for Vectorborne Diseases at the University of California, has been very prolific over the last week adding a significant number of functions to work with the raster type. He finished all the functions listed below (more are to come later).
My question goes as follow:
1) Should we make the effort (and take the risk) of integrating his work for PostGIS 2.0 or should we wait for PostGIS 2.1? Note that these functions are not documented yet.
Sub questions are:
2) When is the feature freeze planned? Is there going to be a branch done? How do you usually deal with future stuff to add during a release cycle?
3) When is the code freeze planned?
Functions to integrate (each function have a certain number of variants):
ST_Band(rast raster, bandnums int[]) #339
ST_MinMax(rast raster, nband int, ignore_nodata boolean, OUT min float8, OUT max float8) #902
ST_ApproxMinMax(rast raster, nband int, ignore_nodata boolean, sample float8, OUT min float8, OUT max float8) #902
ST_Reclass(rast raster, nband int, reclassexpr text, pixeltype text, nodataval double precision) #903
ST_AsGDALRaster(rast raster, format text, options text[], srs text) #901
ST_AsTiff(rast raster, options text[], srs text) #341
ST_AsPNG(rast raster, options text[], srs text) #342
ST_AsJPEG(rast raster, options text[], srs text) #340
Thanks,
Pierre
