[postgis-devel] [PostGIS] #1148: Geocoder has poor results with correct inputs
trac at osgeo.org
Tue Aug 2 01:22:12 PDT 2011
Reporter: darkblueb | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Keywords: |
Comment(by darkblueb):
"ZIP Code Tabulation Areas (ZCTA) are quasi-statistical areas which
attempt to approximate, but are by no means the same as, the USPS ZIP
codes."
wikipedia - Topologically_Integrated_Geographic_Encoding_and_Referencing
this pdf was written before I read that!... At any rate... a couple of
well-chosen example addresses for the regression SQL, definitely, but
also, what I was trying to do was to use data mining techniques to look at
patterns of behavior over large, controlled sets of inputs.. Those samples
on the download site are what I was using as inputs..
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1148#comment:4>
