[postgis-devel] [PostGIS] #1131: Make geocoder faster
    trac at osgeo.org
    Tue Aug  2 19:13:11 PDT 2011
  Reporter:  robe            |       Owner:  robe
      Type:  defect          |      Status:  closed
  Priority:  high            |   Milestone:  PostGIS 2.0.0
 Component:  tiger geocoder  |     Version:  1.5.X
Resolution:  fixed           |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I think speed is good enough for now.  In most cases I'm getting 50ms-
 250ms (closer to 150ms-250ms if I have a lot of states loaded or I have a
 really crappy disk drive like what cloud servers are normally equipped
 with or I run on one of those cheapo drives with lots of space but slow
 disk seek) on a fairly untuned (aside from indexes) windows desktop/server
 running 9.0 or 9.1beta3 with PostGIS 2.0 or 1.5 installed.  Does seem most
 sensitive to quality of disk drive which is not surprising.
 I briefly tested on an 8.4 mostly to make sure things still worked.  I
 think the speeds are more or less the same.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1131#comment:2>
