[postgis-devel] [PostGIS] #1152: SRID_MAXIMUM should be raised to at least 999999999 in liblwgeom.h
trac at osgeo.org
Wed Aug 3 12:27:26 PDT 2011
Reporter: vince | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: srid liblwgeom |
French IGN has defined its own projection codes (authority IGNF) for
French needs (e.g. Lambert 93 with grid transformation support in Proj4
for extra precision) around 310000000. Using these projections to import a
raster fails with error
gserialized_set_srid called with value (310024140) > SRID_MAXIMUM (999999)
Therefore, the 999999 value should be raised to at least 999 999 999.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1152>
