[postgis-devel] [PostGIS] #1148: Geocoder has poor results with correct inputs
trac at osgeo.org
Wed Aug 3 13:33:11 PDT 2011
Reporter: darkblueb | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Keywords: |
Comment(by darkblueb):
Notes on Geocoder 7691:
Input data is 400,000 correct residential addresses in Alameda County
(or subsets thereof)
Two runs
no limit on results ("L_N"),
Result limit = 1 ("L_1")
Comparison Geocoder
Brand-Y commercial geocoder ("Brand_Y")
Observations:
* Less than 0.25 % of addresses had imperfect readings via
normalize_address()
(levenshtein distance between input address and pretty print normalized
address)
* L_1 has roughly 3% of geocoded points not near the actual address
(Brand_Y < 26 thousandths of one percent for the same set)
* L_N has > 10% of points not near the actual address
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1148#comment:6>
