[postgis-devel] [PostGIS] #1152: SRID_MAXIMUM should be raised, gserialized_get/set_srid () should be patched and typemod int too
trac at osgeo.org
Thu Aug 4 10:13:57 PDT 2011
Reporter: vince | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: srid liblwgeom |
Comment(by robe):
Paul,
Is this going to require a dump reload if we change this? I would assume
so for those using typmod at anyrate.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1152#comment:3>
