[postgis-devel] [PostGIS] #1148: Geocoder has poor results with correct inputs
PostGIS trac at osgeo.org
Thu Aug 4 11:06:26 PDT 2011
 Reporter:  darkblueb       |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  high            |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 And to demonstrate -- if I insert this record:
 INSERT INTO tiger_data.ca_featnames( tlid, fullname, "name", predirabrv,
 pretypabrv, prequalabr,
        sufdirabrv, suftypabrv, sufqualabr, predir, pretyp, prequal,
        sufdir, suftyp, sufqual, linearid, mtfcc, paflag, statefp)
 SELECT  tlid, 'el Cajon Ave' AS fullname,'el Cajon' AS name, predirabrv,
   FROM tiger_data.ca_featnames
   WHERE tlid = '125027794' AND name = 'el Canon';
 And then run this query:
 SELECT pprint_addy(addy), ST_AsText(geomout) As coord, rating
         FROM geocode('4533 El Cajon Ave, Fremont, CA 94536',1) As g;
 The answer comes back pretty fast (175 ms on my crappy drive with many
 other states loaded and with out that entry its very slow about 30 secs
 and comes back as you said with the wrong answers)
 with:
              pprint_addy              |          coord           | rating
  4533 el Cajon Ave, Fremont, CA 94536 | POINT(-122.0241 37.5582) |      0
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1148#comment:12>
