[postgis-devel] Common Code
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Aug 9 08:36:22 PDT 2011
On 09/08/11 15:40, Paul Ramsey wrote:
> You think the proj caching is useful outside the pgsql context?
> Me == surprised
> P.
Not so much the caching (as the PROJ.4 API is similar in this aspect),
but the ability to detect memory leaks within the caching code and a
fixed API for caching in general. Then we can write a set of function
callbacks to make adding caching to any other function within PostgreSQL
really easy.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
