[postgis-devel] Common Code
Chris Hodgson
chodgson at refractions.net
Tue Aug 9 11:46:10 PDT 2011
Isn't all this "caching" for storing one or maybe two objects ( proj
contexts, geos geometries, etc) for the length of a single query? I
think any kind of database, in-memory or not, is way overkill. This
doesn't even require a hash table... just a short list of the most
recently used objects.
If there is any place for an embedded DB it is in proj itself, instead
of reading through the entire EPSG file, so that it could have some kind
of index, but that discussion is for another list.
I agree with Mark that if we can come up with a simple design for
abstracting the caching API separately from postgres, that it would be
nice to be able to test it outside of postgres. And it could possibly be
of use to whomever else might be using lwgeom, if in fact alternate DBs
are the primary target user for liblwgeom. Also, understanding that this
is the case, I retract my earlier statement about not seeing the need
for decoupling postgis versions from liblwgeom. I agree with strk's
step-wise approach to moving in this direction.
Cheers,
Chris
aperi2007 wrote:
> >What about using BerkeleyDB in a RAM only configuration as a key/value
> >store? It's mature, stable, and multiplatform.
> Should be sqlite a valid alternative to BerkeleyDB ?
> It also allow a memory-only DB.
> Regards,
> Andrea
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
