[postgis-devel] [PostGIS] #1158: Can't compile under Windows	mingw
    trac at osgeo.org
    Fri Aug 12 18:10:29 PDT 2011
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 To answer your question before you ask it.
 If I:
 cd liblwgeom
 make
 make check
 That works compiles  and make check passes.  So I presume must be another
 ordering issue
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:1>
