[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
trac at osgeo.org
Wed Aug 17 20:57:51 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
I thought maybe it was none of the functions in libpgcommon were being
picked up, but it seems its just the ones in lwgeom_transform.c. The
lwgeom_pg.c that have DATUMS e.g. lwgeom_pg.h seem to have installed fine
since I can use ST_Force_4D etc. from PostgreSQL using this binary.
I did get a notice about proj can't be dynamically linked or something so
perhaps that is a signal. I don't recall seeing that notice before this
move to libpgcommon, but it is possible I just wasn't paying attention.
*** Warning: This system can not link to static lib archive
/c/projects/proj/rel-4.6.1/lib/libproj.la.
*** I have the capability to make that library automatically link in when
*** you link to this library. But I can only do this if you have a
*** shared version of the library, which you do not appear to have.
libtool: link: warning: undefined symbols not allowed in i686-pc-mingw32
shared libraries
I am puzzled though -- why does lwgeom_pg.h have the DATUMS for
lwgeom_pg.c, but yet lwgeom_transform.c the DATUMS are just thrown in
there instead of in the header file. Is there a reason for what seems to
me like an inconsistency? I tried moving over the DATUMS to the
lwgeom_transform.h and it compiled, but didn't seem to solve my problem.
HINT HINT: Mark C., if you are paying attention -- now would be a really
good time to express your words of wisdom since you know more about this
mingw stuff than any of us.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:31>
