[postgis-devel] [PostGIS] #1162: chuck old junk about older versions of PostgreSQL
PostGIS trac at osgeo.org
Wed Aug 17 21:10:09 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Given all the problems I am having, I have been forced to look at some of
 the code we have.
 We've got ifdefs that are just dead weight.
 Case in point:
 libpgcommon\pgsql_compat.h
 We don't support anything lower than 8.4 so none of these conditions
 really makes sense to have.  The file should either be blanked out or be
 gone.
 Same goes for that PG_MODULE_MAGIC ifdef stuff.  All versions we have now
 require PG_MODULE_MAGIC so why do we bother with ifdef.
 Same goes for postgis/lwgeom_accum.c
 We've got code that has:
 #if POSTGIS_PGSQL_VERSION < 84
         result = makeMdArrayResult(state, 1, dims, lbs, mctx);
 #else
         result = makeMdArrayResult(state, 1, dims, lbs, mctx, false);
 #endif
 We don't support lower than 8.4 -- this should be just:
 I'd be willing to cleanup some of this if only I could compile again.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1162>
