[postgis-devel] undefined symbol: gidx_to_string
dustymugs
dustymugs at gmail.com
Mon Aug 22 17:06:43 PDT 2011
Hey all,
I've only be experiencing the following for last day or so. Basically,
when I run the following:
./configure --with-raster --enable-debug
make
cd raster
make check
I get the following in the regress_log:
SET
BEGIN
psql:/home/software/geo/postgis-svn/regress/postgis.sql:65: ERROR:
could not load library
"/home/software/geo/postgis-svn/regress/00-regress-install/lib/postgis-2.0.so":
/home/software/geo/postgis-svn/regress/00-regress-install/lib/postgis-2.0.so:
psql:/home/software/geo/postgis-svn/regress/../raster/test/regress/rtpostgis.sql:39:
NOTICE: type "raster" is not yet defined
DETAIL: Creating a shell type definition.
ERROR: could not load library
"/home/software/geo/postgis-svn/regress/00-regress-install/lib/rtpostgis-2.0.so":
/home/software/geo/postgis-svn/regress/00-regress-install/lib/rtpostgis-2.0.so:
I don't have this problem if I don't run configure with --enable-debug.
-bborie
