[postgis-devel] [PostGIS] #1165: Selectivity extimation of && operator
trac at osgeo.org
Mon Aug 22 19:47:37 PDT 2011
Reporter: edoardopanfili | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
Changes (by robe):
* priority: medium => blocker
* milestone: PostGIS 1.5.4 => PostGIS 2.0.0
Comment:
Okay I'm seeing a problem too. I tried setting up your test but using
pure sql and things seem much worse with my last night build than my
8/3/2011 build.
Here is what I have (note I have postgis 1.5.2, 2.0.0 on same server
cluster in same table space with all same memory configurations:
create table gtest (id int);
SELECT AddGeometryColumn('gtest', 'the_geom', 4326, 'POLYGON', 2);
INSERT INTO gtest (id,the_geom)
SELECT n,ST_Buffer(ST_SetSRID(ST_Point(10 + ((random()*radius*2) -
radius),42 + ((random()*radius*2) - radius)),4326),0.01,10)
FROM generate_series(0, 10000 - 1) As n CROSS JOIN (SELECT 4 As radius)
As foo;
vacuum analyze gtest;
EXPLAIN ANALYZE
SELECT count(*)
FROM gtest
WHERE ST_Intersects(gtest.the_geom,ST_Buffer(ST_GeomFromText('POINT(10
42)',4326),3,2));
-- my 1.5.2: POSTGIS="1.5.2" GEOS="3.3.1dev-CAPI-1.7.1" PROJ="Rel. 4.6.1,
21 August 2008" LIBXML="2.7.6" USE_STATS PostgreSQL 9.0.4, compiled
by Visual C++ build 1500, 32-bit
Aggregate (cost=7179.77..7179.78 rows=1 width=0) (actual
time=178.601..178.602 rows=1 loops=1)
-> Seq Scan on gtest (cost=0.00..7175.00 rows=1908 width=0) (actual
time=0.717..175.485 rows=4021 loops=1)
Filter: ((the_geom &&
'0103000020E610000001000000090000000000000000002A40000000000000454037DB37B31D3E28403309329378F043400300000000002440000000000080434099499099C4831F403209329378F043400000000000001C40FFFFFFFFFFFF44408A499099C4831F40CCF6CD6C870F4640F8FFFFFFFFFF2340000000000080464030DB37B31D3E2840CFF6CD6C870F46400000000000002A400000000000004540'::geometry)
AND _st_intersects(the_geom,
'0103000020E610000001000000090000000000000000002A40000000000000454037DB37B31D3E28403309329378F043400300000000002440000000000080434099499099C4831F403209329378F043400000000000001C40FFFFFFFFFFFF44408A499099C4831F40CCF6CD6C870F4640F8FFFFFFFFFF2340000000000080464030DB37B31D3E2840CFF6CD6C870F46400000000000002A400000000000004540'::geometry))
Total runtime: 178.740 ms
-- This is my 8/3/2011 build
-- POSTGIS="2.0.0SVN" GEOS="3.3.1dev-CAPI-1.7.1" PROJ="Rel. 4.6.1, 21
August 2008" LIBXML="2.7.8" USE_STATS PostgreSQL 9.0.4, compiled by Visual
-- before I upgraded to trunk--
Aggregate (cost=7179.78..7179.79 rows=1 width=0) (actual
time=174.178..174.179 rows=1 loops=1)
-> Seq Scan on gtest (cost=0.00..7175.00 rows=1912 width=0) (actual
time=0.254..170.930 rows=4049 loops=1)
Total runtime: 174.295 ms
-- my 8/22 build -- yikes
Aggregate (cost=7179.75..7179.76 rows=1 width=0) (actual
time=760.503..760.504 rows=1 loops=1)
-> Seq Scan on gtest (cost=0.00..7175.00 rows=1899 width=0) (actual
time=0.242..756.195 rows=4064 loops=1)
Total runtime: 760.648 ms
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1165#comment:5>
