[postgis-devel] [PostGIS] #1169: Test loader/Latin1 fails
PostGIS trac at osgeo.org
Thu Aug 25 08:53:00 PDT 2011
 Reporter:  bnordgren  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  1.5.X
 Keywords:             |
 I've been getting this for a long time:
 SET
 SET
 BEGIN
 psql:/tmp/pgis_reg_28676/loader:5: NOTICE:  CREATE TABLE will create
 implicit sequence "loadedshp_gid_seq" for serial col
 umn "loadedshp.gid"
 CREATE TABLE
 psql:/tmp/pgis_reg_28676/loader:6: NOTICE:  ALTER TABLE / ADD PRIMARY KEY
 will create implicit index "loadedshp_pkey" for
  table "loadedshp"
 ALTER TABLE
 psql:/tmp/pgis_reg_28676/loader:7: ERROR:  value too long for type
 character varying(32)
 Here's my setup. I'm compiling off of trunk and just updated today, but
 it's been doing this for the past couple of months so the exact revision
 number is probably not so critical:
   PostGIS is now configured for x86_64-unknown-linux-gnu
  -------------- Compiler Info -------------
   C compiler:           gcc -g -O2
   C++ compiler:         g++ -g -O2
  -------------- Dependencies --------------
   GEOS config:          /usr/bin/geos-config
   GEOS version:         3.2.2
   GDAL config:          /usr/bin/gdal-config
   GDAL version:         1.8.0
   PostgreSQL config:    /usr/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.0.4
   PROJ4 version:        47
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.7.8
   PostGIS debug level:  0
  -------------- Extensions --------------
   PostGIS Raster:       0.1.6d
  -------- Documentation Generation --------
   xsltproc:             /usr/bin/xsltproc
   xsl style sheets:
   dblatex:
   convert:              /usr/bin/convert
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1169>
