[postgis-devel] [PostGIS] #1333: Support geocoding of cross streets
trac at osgeo.org
Thu Dec 1 00:31:21 PST 2011
Reporter: arencambre | Owner: robe
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Keywords: |
Comment(by robe):
Done at r8275 (also documented). I'm keeping this open though because the
performance is not as good as the project I cut it from. Granted that was
doing a bit of cheating and osme oter things like (500 feet from the
intersection of etc) which most of which is not appropriate for a generic
solution, but I think the performance can be significantly improved. For
the samples I'm doing on my windows box, I'm getting like 3-4 second
timings which is worse than the under 1 second I'm getting in my other
app.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1333#comment:3>
