[postgis-devel] [PostGIS] #1324: Provide a function to read an LWGEOM bounding box and stop reading it directly
trac at osgeo.org
Thu Dec 1 08:15:17 PST 2011
directly
Reporter: strk | Owner: pramsey
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
A good companion to this function would be one that tells you if a
geometry has a box known already or not. For GEOS shortcuts, for instance,
it probably woulnd't make sense to force computation at the postgis side
as GEOS will have to recompute the box anyway and will most likely have
shortcircuits itself.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1324#comment:2>
