[postgis-devel] [PostGIS] #1345: ST_StartPoint, ST_EndPoint regress failure
trac at osgeo.org
Fri Dec 2 07:30:15 PST 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
I just noticed (by accident of course when testing my cross street logic)
and I forgot my data is multilinestrings (though most are just single
linestrings inside a multi wrapper).
This works on my 1.5 install:
SELECT ST_AsText(ST_StartPoint('MULTILINESTRING((1 2, 3 4))'::geometry) );
--returns --
POINT(1 2)
This works on my 2.0 install:
--returns --
NULL
If this is an intentional change, it needs to be documented since it
stands to break a lot of applications.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1345>
