[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a constraint-based view, replace AddRasterColumn with AddRasterConstraints and expand # of constraints on raster columns
trac at osgeo.org
Fri Dec 2 16:44:09 PST 2011
raster columns
Reporter: robe | Owner: dustymugs
Type: task | Status: assigned
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by dustymugs):
Patch attached for implementing raster_columns and raster_overviews as
views. Existing raster_columns and raster_overviews are renamed by
prefixing "deprecated_" to the table name to give users time to run the
functions AddRasterConstraints and AddOverviewContraints.
The function sets for AddRasterColumn, DropRasterColumn and
DropRasterTable still exist though in a limited capability as there are no
raster_columns and raster_overviews tables. This is so that the current
python raster2pgsql.py loader can still be used until the C raster2pgsql.c
is merged into trunk.
Once the C raster2pgsql.c is merged into trunk, the functions for
AddRasterColumn, DropRasterColumn and DropRasterTable will be deleted.
The deprecated raster_columns and raster_overviews tables (prefixed with
deprecated_) will not be touched as it is up to the user to drop those
tables.
With this change from tables to views, 3rd party plugins should be able to
confidently use the information in the raster_columns and raster_overviews
views as the data underlying the views are derived from existing table
constraints. If a value isn't present in the view, the corresponding
constraint does not exist for that specific raster column.
I plan on making an announcement on the postgis-devel list after I've made
the commit so that people can understand the change, see how to establish
constraints for their raster columns and apply the overview constraint to
their overviews. The announcement will be made on Monday 2011-12-05 as
it's Friday evening (for me at least) and I don't expect many people to be
active.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1319#comment:47>
