[postgis-devel] [PostGIS] #1351: ST_Buffer around A LINESTRING crashes the database
trac at osgeo.org
Wed Dec 7 05:53:00 PST 2011
Reporter: royl | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by strk):
I confirm it's fixed with GEOS SVN:
2011-12-07 14:05:30 CET LOG: duration: 197622.410 ms statement: select
st_summary(st_buffer(st_buffer(st_buffer(st_buffer(st_buffer(the_geom, 1),
2), 7), 10), 30)) from bad_raw_trajectory;
st_summary
Polygon[B] with 24 rings
ring 0 has 64521 points
ring 1 has 8 points
ring 2 has 1922 points
ring 3 has 1206 points
ring 4 has 3868 points
ring 5 has 840 points
ring 6 has 293 points
ring 7 has 11 points
ring 8 has 1238 points
ring 9 has 10396 points
ring 10 has 315 points
ring 11 has 53 points
ring 12 has 1028 points
ring 13 has 6463 points
ring 14 has 36 points
ring 15 has 249 points
ring 16 has 273 points
ring 17 has 58 points
ring 18 has 48 points
ring 19 has 126 points
ring 20 has 170 points
ring 21 has 3408 points
ring 22 has 8 points
ring 23 has 9297 points
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1351#comment:7>
