[postgis-devel] [PostGIS] #1354: Problems geocoding addresses containing "ST STE"
trac at osgeo.org
Wed Dec 7 11:30:11 PST 2011
Reporter: bpanulla | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Keywords: |
The geocoder gets confused by addresses with a type of "ST" followed
immediately by an internal address beginning with "STE", even though
normalize_address() appears to handle this without issue.
'''normalize_address()'''
SELECT addy.*
FROM normalize_address('6226 E PIMA ST STE 999, TUCSON') AS addy;
||Address||Pre-Dir||Street ||Street Type||Post-
Dir||Internal||Locality||State||Zip||parsed||
||6226||E||PIMA ST||St||||STE 999||TUSCON||AZ||||t||
'''geocode() with bad string'''
SELECT g.rating, (addy).*
FROM geocode('6226 E PIMA ST STE 999, TUCSON, AZ') AS g;
||Rating||Address||Pre-Dir||Street||Street Type||Post-
||100||||||||||||||Tuscon||AZ||85641||t||
'''geocode() with amended string'''
If you replace "ST" with "STREET" the geocoder performs as desired.
FROM geocode('6226 E PIMA STREET STE 999, TUCSON, AZ') AS g;
||1||6226||E||Pima||St||||STE 999||Tuscon||AZ||85712||t||
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1354>
