[postgis-devel] [PostGIS] #1350: [raster] GDALPolygonize not being set to 1 when compiling with GDAL 1.9
PostGIS trac at osgeo.org
Thu Dec 8 07:52:40 PST 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:  mingw           |
Comment(by dustymugs):
 I'm guessing you either need to set the env variable LDFLAGS such as in...
 LDFLAGS="-L/c/projects/GDAL/rel-trunk/lib" ./configure ...
 or have mingw's ld search path set.  In linux, the search paths can be set
 in  /etc/ld.so.conf and run ldconfig afterwards.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1350#comment:10>
