[postgis-devel] [PostGIS] #1356: [raster] srid in raster_columns view is zero
trac at osgeo.org
Thu Dec 8 11:51:01 PST 2011
Reporter: bnordgren | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by dustymugs):
Are any constraints specified on the raster table? You can add the
constraints using one of the AddRasterConstraints functions. All values
in the view raster_columns (except for catalog, schema, table and column)
are derived from table constraints, so if your raster table/column has no
constraints, most of the columns in raster_columns will be empty or
default to the appropriate unknown value.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1356#comment:1>
