[postgis-devel] [PostGIS] #1345: ST_StartPoint, ST_EndPoint regress failure
trac at osgeo.org
Fri Dec 9 04:34:26 PST 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
I see the behavior or returning NULL as consistent and documented.
Haven't checked the documentation of 1.5 to see if the not-null return was
documented as expected.
Robe: did you ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1345#comment:2>
